2001 Hyundai Elantra Air Conditioning Does not turn off
FIRASZIAD
  • 2001 HYUNDAI ELANTRA
Air Conditioning problem
2001 Hyundai Elantra 4 cyl Front Wheel Drive Automatic
when I try to click AC Condition Button to be turn off the green light still on and the AC still working till I turn the fan to off, even if you set to heat option
Tuesday, June 2nd, 2009 AT 2:58 AM
MMPRINCE4000
  • 8,548 POSTS
Most likely the switch is bad, this repair should be done at shop and depending on car the switch alone may not be replaceable, but entire assy.
While it possible the relay is bad, the light should go off is relay is bad.
Tuesday, June 2nd, 2009 AT 7:08 AM
