2005 Hyundai Elantra A/C and Heating Same Problem
DG6704
  • 2005 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 76,000 MILES
The air conditioning and heating in my car work fine while the vehicle is in motion, but when I have to stop, such as at a traffic light, they do not work. The heat will blow cold air, and the air conditioning will blow warm air.
Saturday, July 10th, 2010 AT 9:57 PM
The heat will blow cold air, check and test the thermostat and also check if the heater core is clogged-up
and the air conditioning will blow warm air-check the air blend door could be stuck in the heat position-Overall for both problems could be coming from the HVAC unit
Saturday, July 10th, 2010 AT 10:32 PM
