2001 Hyundai Elantra
180,000 MILES • 4 CYL • FWD • AUTOMATIC
AMY88
Hey,
When i turn my car on it reeves high then low a few times when i start it. its like a ghost is pushing on the peddle. it is also idling high do you have any idea to what it could be? i have seen a mechanic about this but they say the computer isn't picking up any errors and they cant seem to find out why it is doing it
Oct 14, 2010 at 11:57 PM
KHLOW2008
  • 41,812 POSTS
Hi Amy88,
The idling system is not working correctly. Check the coolant level in radiator, throttle body and Idle Air Control valve. Some cleaning might be required.
Oct 17, 2010 at 3:35 AM
AMY88
Hey KHLow2008,
The coolant level in my car is normal, the throttle body has been cleaned out and check and also the Idle Air Control valve has been replaced but it is still idling high and fluctuating between high and low when turned on...
Oct 17, 2010 at 12:14 PM
KHLOW2008
  • 41,812 POSTS
Is the replaced IAC new or used?
Have you checked for vacuum leakages?
Was the throttle plate stopper tampered with?
Oct 17, 2010 at 11:11 PM
AMY88
The IAC was check and cleaned (used)
here is the list of things that have been done allready
.Scan tool code test
.Comp test
.Vacuum leak test
.Checked cam timing
.Changed plugs
.Checked Leads
.Checked coils
.Checked T.P.S
.Checked Tc-mp sensors
.Checked Earth
Oct 18, 2010 at 8:41 PM
KHLOW2008
  • 41,812 POSTS
The idling speed is too high and it is due to excessive getting past the throttle body.
1. Faulty IAC. Make a gasket to block the IAC air passages and start vehicle to test.
If the idling speed is still high, it is not the fault of the IAC. There is a vacuum leak somewhere. Check if the throttle plate is fully closed. When the throttle plate stopper is tampered with, it would not close fully resulting in surging.
Check the PCV valve.
Oct 18, 2010 at 11:41 PM
AMY88
Hey sorry i have taken so long to reply..
the throttle plate is working in order and is fully closed.
i am having the intake gasket taken apart and looked at cause we cant seem to find any vacuum leaks any where else. dad says looks like someone has tried to bodge it up with some sorta Elastic or some sorta gap filler around the edges.. will let you know how it goes
Thanks for the help much appreciated
Oct 25, 2010 at 11:08 AM
KHLOW2008
  • 41,812 POSTS
You're welcome.
Hope to hear good news from you next time.
Oct 26, 2010 at 12:46 AM
