2000 Hyundai Elantra Power sterring hose
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
CUATHEMOC
The power sterring hose on my car is leaking. I want to buy the hose on the internet becuase is cheaper but there is two kinds hoses the low pressure and the high pressure which one I should buy. Thanks
Aug 24, 2010 at 4:32 AM
SATURNTECH9
  • 30,869 POSTS
Which hose is leaking?The one that is screwed into your pump?Or the one that is held in place by a hose clamp?
Aug 24, 2010 at 5:22 AM
CUATHEMOC
[quote:36dc9ccd87="saturntech9"]Which hose is leaking?The one that is screwed into your pump?Or the one that is held in place by a hose clamp?[/quote:36dc9ccd87]
Is the one that is held in place by a hose clamp.Thanks
Aug 24, 2010 at 5:49 AM
SATURNTECH9
  • 30,869 POSTS
That's your return line so if it's leaking you need to order that one.
Aug 24, 2010 at 6:04 AM
CUATHEMOC
[quote:9b8c149401="saturntech9"]That's your return line so if it's leaking you need to order that one.[/quote:9b8c149401]Thanks satturntech9
Aug 24, 2010 at 6:08 AM
