2000 Hyundai Elantra Please suggest
HYUNDAI_ELANTRA_2K
  • 2000 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 229,000 MILES
When I put my car in the drive mode, it takes some time to get the acceleration and then there is pull/jump when it tries to ship gears internally and I am guessing that it is taking a while before shifting from the first gear (internally as it is automatic). I took it to AAMCO repair center and they did some electrical analysis and told me that they have to disassemble the transmission and fix the seal problem. I was told that this fix would cost me ~$900 and replacement of transmission would cost $1500+. I was also told that the transmission fluid was dark in color. Also the gears are in good shape and they told me something about flares. Please suggest on what needs to be done as investing that much on this car is not worth it as I don't know how long it is going to last or if I choose to sell it off, I will not be even be getting to what this repair costs. If I choose to get the transmission fluid changed, would that help? Also how long do you think that this car is going to last with the current issue.
Thanks in advance for your time.
Tuesday, March 3rd, 2009 AT 9:12 AM
  • 109,885 POSTS
Hi:
If there is a bad seal, it could cause a shift problem. However, with the mileage on the car and the year, I question if it is worth putting the money in to it. But, I don't know what car, condition, problems.
Check out KBB. Com and see what the car is worth. If it is less than the amount of a new trans, I question if I would fix it.
Friday, March 6th, 2009 AT 10:44 AM
