2000 Hyundai Elantra 4 cyl Front Wheel Drive Automatic 108k miles
my engine shuts down intermittantly when the weather is warm. When the engine restarts the crank position sensor code is set in the computer.Should i just change the sensor?also the transmission doesn't upshift right sometimes.could a weak signal from the crank position sensor be causing this?
Apr 2, 2009 at 12:46 PM
