2000 Hyundai Elantra p0303
2000 HYUNDAI ELANTRA
100,000 MILES • 4 CYL • FWD • AUTOMATIC
LARRY GRAY
can reset code but it comes right back. Engine misses all of the time. Replaced plugs, no change. Inductive timing light will flash rapidly on cyl 1,2,and 4 but on 3 sometimes no flash or very sporadic, plug wire measures about 2000 ohms. Reconnected throttle pos sensor and the connecter to the coil module...no change. Suspect a new coil module will fix it. What do you think? no problems with the engine running untill this happened...ie no warnings or other unusual symptoms. Thanks Larry
Jan 20, 2008 at 10:39 PM
  • CAR REPAIR CONTRIBUTOR
A misfire in a specific cylinder should lead you to check the spark plug, fuel injector and compression.
Jan 20, 2008 at 11:19 PM
