2000 Hyundai Elantra Hyundai shuts off (no gas)
133,000 MILES • 4 CYL • FWD • AUTOMATIC
YNWENDI
While driving down the interstate, the car just shut off shortly after filling up with gas. The computer (ECU) fusible link was blown and the pump would not run. It was replaced, blew again. We replaced the fuel pump thinking that was the problem. The car runs great at idle and RPM's when sitting. If you drive the car the fusible link will blow within a mile. I have no idea what could cause this.
Apr 3, 2009 at 1:01 AM
RACEFAN966
  • 5,029 POSTS
Ok what number of fuse blows? I am looking at wiring diagrams for you car and it would be very helpful if you could tell what number the fuse is as that is how the wiring diagrams are set up. There is more then one fuse for the ECU and fuel pump and pump relay and so on. Get back to me and we will go from there.
Apr 4, 2009 at 2:35 AM
