Transmission problem
2000 Hyundai Elantra 4 cyl Front Wheel Drive 157000 miles
DTC Codes P0732 & P0734. I looked up the codes and they are gear 2 and 4 incorrect ratio, respectively. Is this a mechanical issue or a sensor issue? I checked fluid levels, all is fine. How do I fix this?
Thank you,
Chris Meier
Thank you,
Chris Meier
Sep 20, 2008 at 11:53 AM
