2000 Hyundai Elantra cylinder 4 misfire
NESTAR
  • 2000 HYUNDAI ELANTRA
  • 4 CYL
  • 62,000 MILES
Hi.I have a problem with my 200 Hyundai elantra. About 2 days ago on my way home from work, my engine start to miss and function irregular. So I plugged in the ob2 and i've got the code:PO304 engine cylinder 4 misfire.I change the spark plugs and the engine still goes in 3 cylinders.I check if the spark plugs get juice from the coil. So I unplugged every wire from cyl. # 1, and the engine almost died on me, but I plugged the wire right back in the coil.I did the same with cyl. #3 and #2 and i've got the same result. Except with cyl.# 4. The flame -spark- was there but the engine didn't recognize the difference when I unplugged the wire from the coil or when I plugged back in the coil.
If you guys can give me any suggestions of what it my be the problem, I will appreciated. Thanks
Monday, February 1st, 2010 AT 9:07 PM
Check compression and injector for #4 cylinder.
Tuesday, February 2nd, 2010 AT 5:15 AM
NESTAR
Spark plug wire for cyl #4, was worn out. Changed it and the car runs fine again. Thank you guys for your time to help me with suggestions.
Sunday, February 7th, 2010 AT 2:59 PM
Related Engine Misfire Content
Intermittent Misfire
VIDEO
