2000 Hyundai Elantra car vibrates
86,000 MILES • 4 CYL • 2WD • AUTOMATIC
WINEISGOOOD
Hi all,
A week ago I have changed the tires, one cv axel (another one changed 5 months ago) and brake pads on my 2000 automatic Hyunday Elantra . Now the car vibrates at over 65 m/h. Almost forgot to mention...I had the tires balanced as well.
Any thoughts?
Thank you
Feb 21, 2009 at 2:19 PM
  • 110,246 POSTS
Hi:
Does this happen all of the time? Do you feel the vibration more in the steering or the seat?
Feb 22, 2009 at 6:42 AM
WINEISGOOOD
I feel the vibrations in the steering wheel and the floor...and yes it happens all the time.
Thank you for your thoughts.
Feb 22, 2009 at 9:38 AM
  • 110,246 POSTS
Have you checked for a bent wheel or belt shift in one of the tires?
Feb 22, 2009 at 9:58 AM
WINEISGOOOD
No i did not check if the wheels are bent. Is it possible that the cv axel was not properly installed? Recall that I don't have any problem until 65 m/h.
I guess a tire rotation might prove the bent wheel ideea, so I'll give it a try.
Feb 22, 2009 at 4:01 PM
ED MILLINGTON
2004 elantra vibrates above 62 as well. Rotating didn't cure.
Mar 13, 2009 at 5:40 AM
