2000 Hyundai Elantra Blow By Hose Deteraited into intake.
M-SCOTT
Engine Mechanical problem
2000 Hyundai Elantra 4 cyl Front Wheel Drive Automatic
The blow by hose between the valve cover and connected to intake fuel injection system, deuterated sending hose parts and de-bree to the intake making engine run bad
Mar 2, 2009 at 8:54 AM
  • 110,248 POSTS
Hi:
Are you able to remove anything to gain access and clean it? If you can, I would recommend it. If that doesn't help, the intake may need removed to get all debris from the intake and engine.
Mar 6, 2009 at 2:46 AM
