1999 Hyundai Elantra reverse lights
130,000 MILES • 4 CYL • FWD • MANUAL
BRIANPERRY1968
my reverse lights dthe fuse that controls them and dont work and cant find the fuse and if not the fuse any ideas why its the only lights that dont work.
Jul 28, 2010 at 1:22 PM
KHLOW2008
  • 41,812 POSTS
Hi BrianPerry1968,
The reverse light fuse is # 9 (10A) in dash fuse box, under left side of dash at kick panel.
If the fuse is good, check the back-up light switch mounted on transaxle. Disconnec the switch and use a jumper across the terminals if the bulb lights uu with ignition turned on, the back-up light switch is bad.
Aug 1, 2010 at 3:02 AM
