1999 Hyundai Elantra cant start
310,044 MILES • 4 CYL • 2WD • AUTOMATIC
AUTOSCAN
dear bob/ken
i have vehiacal cant start, i check theirs no spark, i check electrical its ok, but i dnt knw how to test cam, crank shaft sensor with multimeter
May 4, 2010 at 3:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
CAM SENSOR
Pin 1 is +5V, pin 2 is Ground and pin 3 is the signal. Use analog voltimeter in pin 2 and 3. Crank the engine: the pointer of the voltimeter shoud oscilate in range 0V to 5V.
CRANK SENSOR
do a continuity test on the crank sensor, if it reads zero, it is bad.
May 4, 2010 at 4:23 PM
