1999 Hyundai Elantra both rear brake lights off
115,000 MILES • 4 CYL • FWD • AUTOMATIC
PLDGSPH
Rear lights work, rear turn signals work, middle brake light in rear window works, but both rear brake lights do not. Check fuse box under dash and it appears that none of them are blown. Is there something else I should check? Where is it located? Thanks.
Jul 21, 2010 at 2:00 PM
  • 110,248 POSTS
If the 3rd light is working, then the switch is good. Which means you have to start checking for wiring issues.
Aug 23, 2010 at 4:06 PM
