1998 Hyundai Elantra Timing Belt
100,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBDAN84
I have a 1998 Hyundai Elantra that I have replaced the timing belt on my friend claims when it broke down that it continued to run till he shut it off but the timing belt was shredded at the crank. Now it won't start pop misfire nothing it just turns over. Ive checked fuel/fire all good. I'm guessing valves or ECU maybe???
Feb 26, 2010 at 11:08 AM
  • 31,937 POSTS
Hi there,
There is no way that it would run until it was turned off, if the belt fails the engine will stop instantaneously, you have bent valves in the head this is an interference type engine, the head must be removed.
mark (mhpautos)
Feb 26, 2010 at 12:02 PM
