1997 Hyundai Elantra fuel
130,000 MILES • 4 CYL • FWD • AUTOMATIC
RLARABEE
i am getting fuel from the pump to the rail but it will not fire. but if i hit it with starting fluid it will fire off that and die what can i do to fix it
Apr 22, 2010 at 12:19 AM
KHLOW2008
  • 41,812 POSTS
Hi rlarabee,
Unplug the injector wire harness and test for battery voltage at one of the terminals with ignition switch turned ON.
If voltage is available, get a noid light and test them for pulse while cranking the engine.
Apr 22, 2010 at 5:43 AM
