1996 Hyundai Elantra BRAKE LIGHTS
UNICE
Brakes problem
1996 Hyundai Elantra Four Wheel Drive 48000 miles
tHE BRAKE LIGHTS DON'T WORK, TRIED EVERYTHING: BULBS, FUSE, , DON'T KNOW HOW TO TELL EHRE THE PROBLEM IS. tHE OTHER LIGHTS UPFRONT WORK FINE. I'VE READ THE OTHER ARTICLES IN THE FORUM, BUT I'M CONFUSED AS TO WHICH WIRE TO CHECK AND WHERE IS IT LOCATED, ALSO, WOULD YOU BY ANY CHANCE HAVE "HOW TO" INSTRUCTION E-BOOKS? THANK YOU FOR YOUR TIME.
Nov 9, 2008 at 6:49 PM
  • 31,937 POSTS
Hi there ,
Check that there is power at and through the brake light switch when the pedal is pressed, the switch is mounted at the top of the brake pedal under the dash.
mark(mhpautos)
Nov 9, 2008 at 7:05 PM
