1995 Hyundai Elantra No compression on one cylinder (valve)
84,000 MILES • 4 CYL • 2WD • AUTOMATIC
JPKLAGODBLESS
The car has 0 compression on the cylinder on the passangers side of the car. The other three read good. I was told to take off the top to see if there was a valve bent. Can you tell me how to tell if one is bent? What else could cause the bad commpression? Thank You
Feb 25, 2009 at 6:43 AM
  • 75,988 POSTS
Get a cylinder leakdown test this will tell you if its rings/valves and cylinder
Feb 25, 2009 at 6:46 AM
