1992 Hyundai Elantra fuel problem...maybe
180,000 MILES • 4 CYL • FWD • AUTOMATIC
CARVER0529
Have 1992 hyundai elantra at times when go to accelerate have no gas seems to sort of hop if punch gas pretty much chokes and dies idles quite fine if turn car off and wait 5 minutes some times less problem goes away and can get anywher between 1-15 km before it starts again. just feel like engines getting no gas. PLEASE HELP
Jul 31, 2009 at 5:56 PM
  • 75,988 POSTS
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jul 31, 2009 at 10:01 PM
