2001 Hyundai Coupe Yellow light on saying CHECK
2001 HYUNDAI GENESIS COUPE
56,000 MILES • 6 CYL • FWD • MANUAL
SINCIA5
Light came on when setting off took it to a garage and was told it is the engine light. Took plugs out and did a test on all 4 valves, I was told engine was alright and new plugs or leads could be needed. Please tell me if this could be the only problem. I will take it to garage tomorrow and leave it for them to deal with whilst I go to work. HELP I am female and no nothing, I have not got a manual book to help me.
I await your reply, thank you so much, Cyn
Sep 27, 2010 at 10:03 AM
WRENCHTECH
  • 20,761 POSTS
The "check engine" light is an indicator for a system that monitors many electronic functions in the system, also called the "malfunction indicator lamp" (MIL). It can come on for any of hundreds of different causes from any of the systems that the computer monitors. Some are very important and can lead to further component or engine damage and some are emissions related not as serious but still a problem and need to be repaired.
Your first step is to have the computer scanned to retrieve the trouble codes that were set when the check engine light came on. Those codes will give you specific information about what the computer saw and will get you pointed in the right direction to find your problem. With a 1996 or newer and some 95 cars and you have an AutoZone or Advanced auto parts in your area, they will read them for free. Once you have these code numbers, we can be a lot more specific about what your problem may be.
Sep 27, 2010 at 10:05 AM
