Hyundai amica
102,000 MILES • 1.0L • 4 CYL • FWD • MANUAL
BIGBROTHER03
Hi I have a hyundai amica 1.0 si 2002.the Eml light is on and reading misfire fault code on different cylinders.when I clear the codes the car drives well for 5 minutes then starts stalling again and looses all power I have given it a service as it was due one anyway so new plugs air filter and oil and filter.i am thinking it might be the coil pack but I don't really want to spend out with out being sure.i haven't changed the fuel filter yet but I am thinking that if that was partially blocked it would do it all the time.does anyone know of a common fault on these models that causes the issues I'm having.
Jan 31, 2016 at 3:29 AM
  • 55,691 POSTS
Hello, BIGBROTHER03
Its sounds like you hit it on the money a coil pack would definitely cause the problem you are describing, this problem is difficult to test though, change the plugs for sure, please let me know what happens
Feb 6, 2016 at 11:07 PM
BIGBROTHER03
Hi thanks for your response I've changed the coil pack and the car is running nice now.
Feb 7, 2016 at 2:43 AM
  • 55,691 POSTS
Good to hear, glad we could help. Tanks for using 2Carpros.com
Feb 8, 2016 at 12:33 AM
