2008 Hyundai Accent comparision
45,678 MILES • 4 CYL • FWD • MANUAL
NJAIN_NK
is coolant pressure high or oil pressure?
Sep 27, 2009 at 6:45 PM
  • 110,248 POSTS
I'm not sure I understand the question. The oil pressure can be somewhat high, but will not have an affect on the driver. THe coolant will pressurize in the radiator and can burn you if you open the radiator when it's hot.
Sep 28, 2009 at 4:11 AM
NJAIN_NK
i requried the difference in pressure of both the things
Sep 30, 2009 at 5:29 PM
  • 110,248 POSTS
The oil pressure of an average car runs around 40PSI. Most cooling systems have a 15lbs cap that releases pressure when that point is reached.
Oct 1, 2009 at 12:21 AM
