2007 Hyundai Accent water leak
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
ABELL7
i have a 2007 hyundai accent and i noticed that it is leaking a lot of water when the engine is running, even with the air turned off. i notice it is a lot more that the condesation you get from your a.c. being on. do you think this could be a water pump issue? the drip is a clear liquid looks like water to me?
Oct 12, 2010 at 12:44 AM
SATURNTECH9
  • 30,869 POSTS
If it's clear water dripping it's not from your cooling system because unless you only have just water in your radiator and no coolant that wouldn't be possible for it to leak clear pure water out of the water pump etc..It's most likely from your a/c.
Oct 12, 2010 at 9:15 AM
