2007 Hyundai Accent brake lights
10,000 MILES • 4 CYL • 2WD • AUTOMATIC
SENNATESKATER
My cars brake lights dont illuminate, the regular running lights are fine but when you push the brake pedal they dont illuminate any suggestions?
Dec 7, 2008 at 12:29 PM
ZACKMAN
  • 4,202 POSTS
Is the center brake light (the one in the rear window) working? If it is, replace both bulbs. If it is not, go back to Hyundai hand have them check the brake light switch.
Dec 10, 2008 at 4:51 PM
BOUDREAUED
I have a 2007 Accent and notice if my driving lights are not all the way on, my back lights won't come on.
Dec 27, 2008 at 7:24 AM
ZACKMAN
  • 4,202 POSTS
boudreaued,
Your vehicle has the daytime running light. Looking at the diagram, once you turn on the light switch (for side markers), your DRL relay shuts down and relays for side markers and taillights come on.
You may want to check inside the junction box, left side of dash, for your taillight relay. Do this, pull your hand brake up, start the engine. Turn the light switch to side markers, not head light. Go out of the car, and check to make sure that your taillights work. They should come on with the side markers, not headlight.
Dec 27, 2008 at 3:35 PM
