Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Accent
Exterior Light
Brake Light
REPLACE/REMOVE
2006 Hyundai Accent brake light
2006 HYUNDAI ACCENT
78,000 MILES • 4 CYL • 2WD • AUTOMATIC
TRCARGILL
MEMBER
1 POST
how do i replace the brake light bulb
Jan 8, 2010 at 7:22 PM
Experienced Mechanic
Open the trunk and remove carpet from behind the tail light assembly. There you will see wingnuts holding the assembly in place. Remove them, the assembly will come off, then you can access the light socket to replace the bulb.
Jan 20, 2010 at 12:16 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
