2005 Hyundai Accent windshield wiper fluid motor
777MAN
Electrical problem
2005 Hyundai Accent 4 cyl Two Wheel Drive Manual
I drive a '05 Hyundai Accent hatchback and I tried spraying washer fluid on the front and rear windows, but it only comes out small amount in the front and none in the rear. I can hear the motor running. The fluid is full and doesnt appear to be leaking on the ground, what do I do? I'd like to do this myself if possible.
Any help will greatly be appreciated,
Thanks,
Pat M.
Feb 21, 2009 at 12:37 PM
  • 110,248 POSTS
Pat:
remove the rubber hose from the motor that supplies the solvent to the windows and see if there is pressure coming from the pump. If there is, you most likely have a freeze up somewhere in the line. Also, if they are not working at all, make sure there is power to the motors. If there is and they still don't work, you may have to replace the motor.
Let me know what you find.
Feb 22, 2009 at 6:21 AM
777MAN
I'll try that, I just cant seem to find the motor that goes to the tank. The fluid tank is hidden from the top and from the bottom.
Thanks,
Pat Montague
Mar 3, 2009 at 8:07 AM
  • 110,248 POSTS
I just looked the part up and it does appear to attach to the bottle. You may have to access it through the inner fender if you can't see if from the engine compartment.
Mar 3, 2009 at 8:59 AM
