fuse panels are and what the fuses for the trunk light?
2005 HYUNDAI ACCENT
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
POMAL
no lights in the trunk are out I need to check the fuses
May 27, 2009 at 7:03 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It might not be a fuse but rather the headlamp relay in your vehicle that has caused the headlamp outage. Here is a tutorial showing how to test a relay:
The headlamp relay is located under hood in the engine compartment fuse-relay box. I've attached pictures below showing the location of the relay on your car. Hope this helps and thanks for using 2CarPros.
Jun 24, 2021 at 3:34 PM
