2005 Hyundai Accent My car suddenly died and now will not s
93,000 MILES • 4 CYL • FWD • MANUAL
DIMO VIROSTKO
My car suddenly died as I was making a turn onto another street and would not start back up. It will crank over but will not fire up. It has been running perfectly up till now and I have kept up with the basic maintenance on it. What could be wrong with it.
Dec 28, 2009 at 3:56 AM
  • 75,988 POSTS
Could be a fuel or spark problem -Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Dec 28, 2009 at 6:55 AM
