2005 Hyundai Accent CAR DECELERATES BEFORE CATCHING UP WHEN
2005 HYUNDAI ACCENT
NAT ASPIRATED
Engine Performance problem
2005 Hyundai Accent 4 cyl Two Wheel Drive Manual
I have been learning everything the hard way till i came to this forum.
As I said my hyundai 1.5 sohc is giving me this trouble for an year. Ie when I apply accelerator in a sudden motion the car bogs down and you can feel it adecelerating. So much so that you have to downshift to catch up with traffic. I have changed:
Fuel/air /oil filters
Oxygen sensor
Spark plugs
cleaned the injectors
The REAL interesting part is that this problem is resolved and the car acelerates nicely when I am on my LAST 2~5 ltrs.
I e the last remaining 1/2 inch of fuel level rectifies this. How is it possible.
Jun 5, 2010 at 6:39 PM
Check the fuel pressure and volume delivery of the fuel pump. That don't cut it do below Inspect and test all the following
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 5, 2010 at 7:00 PM
