2005 Hyundai Accent Brake and license plate light on hatch
2005 HYUNDAI ACCENT
64,000 MILES • 4 CYL • 2WD • AUTOMATIC
MOMO_LAX03
I was recently pulled over because my license plate light and the third brake light in the middle of my back windshield were both out. I replaced the lights for the license plate but they still do not work. The mechanic said their initial guess is that the wiring is broken because there does not seen to be any power current. Do you think this is the case and how much would it cost to re-wire? I'm a girl and don't want to get taken advantage of for being naive about cars.
Thank you!
Dec 30, 2009 at 8:58 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Something is causing it to loose power before the light. I would say the most likely cause is a bad wire. As far as parts, there shouldn't be much of anything to fix the wire. The problem is finding where the problem is. Has he give you a quote?
Jan 20, 2010 at 8:22 AM
