2004 Hyundai Accent timing belt
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOSECORONA_18CORONA
how to replace a timing belt
Jul 29, 2010 at 11:07 AM
  • 75,988 POSTS
TIMING BELT
Removal
Lift vehicle using a jack. Remove engine support bracket, if necessary. Loosen, but do not remove water pump pulley bolts. Remove all accessory drive belts. Remove pulleys from crankshaft and water pump.
CAUTION:DO NOT rotate engine counterclockwise. If reusing timing belt, place reference mark on timing belt to indicate direction of rotation before removal.
Remove timing belt covers and gaskets, noting bolt length and location. Rotate crankshaft clockwise to align timing marks on crankshaft and camshaft sprockets.
If reusing old belt, place mark on belt to indicate direction of belt rotation. Loosen timing belt tensioner bolts, and move tensioner inward toward water pump. Temporarily tighten bolt in slotted side of tensioner. Remove timing belt.
Jul 29, 2010 at 11:49 PM
