door cannot open from outside, lift-up lever doesn't work.
Feb 7, 2010 at 3:39 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
2CARPRO JACK
CAR REPAIR CONTRIBUTOR
Sounds like the outside door handle may be broken.You will need to remove the inner door panel to gain visual access to the inside of the door so you can see if the outer handle is broken where the rod attaches. if so it will need to be replaced
