2004 Hyundai Accent CODE po772
30,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOEFROMTX
I have code PO772 on a Hyundai Accent. It gets stuck on first gear; however, once it get moving, it drives fine.
It happened after I hit a bump. What could be the problem? Thanks.
Jan 18, 2010 at 11:07 AM
  • 110,248 POSTS
There is a problem with a shift solenoid. It is stuck in the on position. The bump may have caused it.
The sensor will need replaced. It is in the transmission, under the filter assembly. It isn't too big of a job.
Jan 20, 2010 at 12:06 AM
