2004 Hyundai Accent
ELGRINDER
Electrical problem
2004 Hyundai Accent 4 cyl Front Wheel Drive Automatic
I AM UNABLE TO REMOVE THE ELECTRICAL CONNECTION TO THE HEADLIGHT (RIGHT). OBVIOUSLY THERE IS A SIMPLE SOLUTION. NEITHER PULLING, TWISTING, OR ANY ATTEMPT TO RELEASE THE ELECTIRCAL CONNECTION HAS WORKED. THE MANUAL DOES NOT SHOW THE SAME TYPE OF CONNECTOR AS ON THE LIGHT ASSEMBLY.
Aug 23, 2009 at 12:57 PM
ELGRINDER
[quote:751d1f793b="elgrinder"]Electrical problem
I AM UNABLE TO REMOVE THE ELECTRICAL CONNECTION TO THE HEADLIGHT (RIGHT). OBVIOUSLY THERE IS A SIMPLE SOLUTION. NEITHER PULLING, TWISTING, OR ANY ATTEMPT TO RELEASE THE ELECTIRCAL CONNECTION HAS WORKED. THE MANUAL DOES NOT SHOW THE SAME TYPE OF CONNECTOR AS ON THE LIGHT ASSEMBLY.[/quote:751d1f793b]
Aug 23, 2009 at 1:00 PM
