2004 Hyundai Accent
50,000 MILES • 6 CYL • FWD • AUTOMATIC
NUBIANQ1
I have a 2004 hyundai accent and the transimission bearing is loose. I need to know if I have to replace the whole transmission or can I just have the bearing(s) replaced? thanks
Aug 21, 2009 at 10:58 AM
MIKE.SHRUM
  • EXPERT
  • 43 POSTS
Almost any shop should be able to put just bearings in it. Alot of times you find were on syncros also so swapping or overhauling your transmission might be a good idea. My suggestion is find a shop you are comfortable with and talk to them about putting a bearing kit in it
Aug 22, 2009 at 9:14 AM
