2003 Hyundai Accent Timing Belt
2003 HYUNDAI ACCENT
KARANFORWWR
Engine Mechanical problem
2003 Hyundai Accent 4 cyl Two Wheel Drive Manual 20000k miles
hello first of all thanks for listening to som any queries of people from all over the world.
I own a hyundai accent 1.6ltr. 2003 model vehicle. I havent driven it much & its done 20000 kms. just tell me whether I should change the timing belt on her or not?? I am asking this because in the mannual it just says that, it should be replaced at 80000 kms. but no time is mentioned.
She's 7 yrs. old so I am worried...kindly reply.
thanks a lot!!!
Aug 8, 2010 at 7:46 PM
EDWARD.S
  • 166 POSTS
Hi,Based On the age of the car ,Yes change The timing belt.The belt Is Made of Rubber ,it Does Go Bad after a while.Make sure you check the timing marks carefully before starting.
Hope This Helps You,
Good Luck
Edward S.
Aug 8, 2010 at 10:09 PM
KARANFORWWR
thanks a lot for the reply...please tell me can i do this job after a couple of months as its rainy season here and work is difficult??
one more thing can u help me with accent 1.6 timing marks & process to do so.
thank you once again!!!
Aug 9, 2010 at 4:50 AM
EDWARD.S
  • 166 POSTS
Hi,I have the info On your car.i Can sent it to you .If you Give me your email address. Read all the directions before doing the job.Any Follow each step as per instructions.I don't post the directions on here cause ,i was told it's not readable last time.
Good Luck
Edward S.
Aug 11, 2010 at 10:32 PM
KARANFORWWR
hi edward my email id is, karanforwwr@rediffmail.com. please pass the info. and even tell me can i get this work done after 2-3 months or it must be done right away???
thanks a lot for help & reply!!
Aug 12, 2010 at 12:23 AM
