2003 Hyundai Accent Replacing front wheel bearings
150,000 MILES • 4 CYL • 2WD • MANUAL
LTCBAILEY
How would I replace the front wheel bearings and what tools would I need?
Jul 10, 2008 at 6:51 AM
KHLOW2008
  • 41,812 POSTS
Hi ltcbailey,
You need to remove the CV nut, brake calipers and mount and rotor.
Pull hub out with a PULLER and remove knuckle assy. Remove circlip and press bearing out with hydraulic press.
A step by step detailed explanation is best acquired through a repair manual.
Jul 20, 2008 at 3:18 AM
