2003 Hyundai Accent No turn-over also Shifter locked in par
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
BRENDANK
The battery appears to be charged but car starter does not attempt to operate. Also Gear Shift locked in park. I can't shift to Neutral to push out of parking bay.
Jan 13, 2010 at 4:13 AM
  • 110,248 POSTS
First, make sure you are getting power from the battery. Using a multi meter, check to see if the battery is producing 12+ volts. If it is, have a helper turn the key to the start position while you check for voltage to the smaller wire on the starter. You should be getting 12+ volts.
Let me know what you find.
Jan 27, 2010 at 5:32 AM
