2003 Hyundai Accent my car
RENWICK101
2003 Hyundai Accent 4 cyl Front Wheel Drive Automatic
i changed the crank sensor and my car started. the next day it did not start would you know whats wrong?
Mar 3, 2010 at 7:39 AM
  • 75,988 POSTS
Pick your symptom-get back with some result.
**Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Mar 18, 2010 at 4:44 PM
