2003 Hyundai Accent engine ticking
60,000 MILES • 4 CYL • 2WD • MANUAL
ARZFAN
  • 8 POSTS
I have a 2003 Hyundai 1.6 dohc the engine is making a ticking sound in the top of the engine what is causing this?
Apr 27, 2008 at 4:56 AM
  • 31,937 POSTS
Hi there,
This could just be a sticky lash adjuster, try adding a good quality engine flush and change the oil and filter, this may do the job for you.
Mark (mhpautos)
Apr 27, 2008 at 10:45 AM
ARZFAN
  • 8 POSTS
i tried that didn't do anyrthing
Apr 27, 2008 at 11:38 AM
  • 31,937 POSTS
Hi there,
If that is the case the lash adjuster will have to be replaced.
mark (mhpautos)
Apr 27, 2008 at 11:43 AM
ARZFAN
  • 8 POSTS
is that an expensive fix? and of you don't how long before it ruins the engine?
Apr 27, 2008 at 11:45 AM
  • 31,937 POSTS
Not to sure if you can do it with out removing the head.. I don't have access to the data base just yet to find out. It wont do much harm in the short term but you will run the risk of burning a vale at some stage, i would get it looked at sooner rather than later.
Mark (mhpautos)
Apr 27, 2008 at 11:50 AM
ARZFAN
  • 8 POSTS
are you sure that engine has lash adjusters i looked at auto parts stores and they only go up to 2002 for them
Apr 27, 2008 at 12:06 PM
  • 31,937 POSTS
Do yopu have an engine code, will re chek my info to make sure.
Apr 27, 2008 at 12:18 PM
ARZFAN
  • 8 POSTS
what kinda engine code ?
Apr 27, 2008 at 12:40 PM
  • 31,937 POSTS
There will be an engine I.D.code like G4ED or similar will need this to make sure if lash adjuster engine or shim type or manual adj... my book says lash type so we better make sure
Apr 27, 2008 at 12:48 PM
ARZFAN
  • 8 POSTS
where can i find this code?
Apr 27, 2008 at 12:49 PM
  • 31,937 POSTS
Depending on engine fitted, should be on block below No 1 spark plug or rear of block above bell housing, may also be on a sticker under bonnet or on rego label if it has the engine No included.
Apr 27, 2008 at 12:58 PM
ARZFAN
  • 8 POSTS
the only number i see is DA080
Apr 27, 2008 at 1:04 PM
  • 31,937 POSTS
OK .. i will need the engine code .. i will see what i can fine out when i can get back on the data base
Apr 27, 2008 at 1:25 PM
ARZFAN
  • 8 POSTS
did you find anything else out?
Apr 28, 2008 at 11:05 AM
