Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Accent
Exterior Light
Brake Light
Switch
2003 Hyundai Accent Brake lights
2003 HYUNDAI ACCENT
119,000 MILES • 4 CYL • 2WD • AUTOMATIC
DJCLOE
MEMBER
1 POST
Brake lights will not go off, where is the brake switch and how do I fix it?
Apr 1, 2009 at 5:43 AM
ARC_55
MEMBER
the brake switch is located on the bracket for the brake pedal. Once the pedal is depressed it hits the switch to turn the brake light on.
Simply unplug the switch and see if the brake lights go out.
Apr 1, 2009 at 5:58 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
