Where is the crankshaft position sensor
AHANSON45
Four cylinder front wheel drive automatic 118,000 miles.
I have looked everywhere on the internet, and I tried looking for a Chilton's on this car but I cannot find somewhere to show me where the crankshaft position sensor is.
I drove 2,300 miles on it in three days and it worked fine until a day later when I tried starting it. I had a little trouble starting it, but it started up nonetheless, then as I was backing up it just shut off. Then it would not start. It would crank and sound like it is about to start, but it just does not. I checked for a spark and there was none.
I know it could be a number of things. But i want to check the crankshaft position sensor but cannot find it. Thanks for your help.
Aug 23, 2010 at 7:27 AM
DOCFIXIT
  • 18,828 POSTS
On left side engine near exhaust. See diagrams.
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_579.jpg
https://images.2carpros.com/forum/automotive_pictures/198357_Grafic_3_141.jpg
Aug 23, 2010 at 7:32 AM
AHANSON45
thanks, i was able to locate it, but unfortunately, that was not the problem. but the camshaft sensor looks pretty fried.
Aug 23, 2010 at 3:45 PM
DJOYC
Four cylinder front wheel drive manual
Hi! I need to replace (or actually have my "male" friend replace) my crankshaft sensor in my car. I need to know the exact location of it for him and be able to verbally direct him to it over the phone!
I would greatly appreciate any help and if a diagram could possibly be included (or you can lead me to one) that would be awesome!
Thank you so much, Danette : )
Jan 10, 2017 at 4:21 AM (Merged)
  • 75,988 POSTS
1.5L.
https://images.2carpros.com/forum/automotive_pictures/12900_1_3.jpg
1.6L is on item number 6.
https://images.2carpros.com/forum/automotive_pictures/12900_16_1.jpg
RIEBED
  • 111 POSTS
Is it just a take off put on or are there any special settings-is the camshaft sensor the same to replace?
crank sensor is behind the crank pulley. the timing belt has to be removed to get to it.
why are replacing both sensors?
RIEBED
  • 111 POSTS
Thanks for replying-I just decided not to replace the crank sensor-I had no idea the timming belt needed to come off thats very labor intensive-I trhought I would be proactive and replace the sensors since they are realitively cheap-avoid problems in the future-I was told if the crank sensor goes out then the care just cranks and doesn't fire is that true?
yes, but is not a common failure. i would keep them in case of a future failure, if it ever occurs.
ANONYMOUS
  • 0 POST
Where is the crank shaft position censor located on my car?
RANDICO
  • 174 POSTS
The CKP is located on the left side of engine block ,near the flywheel,
  • 55,627 POSTS
The sensor is located near the front of the engine down low, here is a guide that will give you an idea of what you are in for when changing the sensor with e diagram (below) of where it is on your car.
Cheers, Ken
Jul 19, 2017 at 6:25 AM
