2002 Hyundai Accent FUSE
SEAN-KELLY
Electrical problem
2002 Hyundai Accent 4 cyl Front Wheel Drive Automatic
2002 hyundai accent 4 cylinder the front marker light rear tail light plate light all on the driver side and dash lights run off of one fuse that fuse keeps popping. i assume there is a short some where in the wiring. is there a known place in the wiring that i can look at to fix this problem or is it not even the wiring
Feb 2, 2009 at 8:00 AM
ZACKMAN
  • 4,202 POSTS
Usually in the rear light connection between the tail light and the plate light. Check for frayed or corroded wire touching metal.
Feb 3, 2009 at 5:03 PM
