While making a turn to the left I hear a clicking noise, however it does not occur when turning right?
Mar 26, 2008 at 4:30 PM
SERVICE WRITER
✓ASE Certified Mechanic
FAir chance of a cv joint going bad. Take a look for a torn boot on the axle. That is a tell tale sign that you'll need an axle.
Mar 26, 2008 at 4:45 PM
FL2CHY
MEMBER
I thought it to be the cv joint as well however they changed the master cyclynder and it seems to be gone could this have been the cause?
Mar 30, 2008 at 6:49 PM
SERVICE WRITER
I don't see any logic in that at all...but things like this happen in this industry. I don't see how it could cause any noise...
Unless there was a fluid restrction of a sort happening that higher pressure was put on that side causing the brakes to be making the noise.
Mar 30, 2008 at 7:33 PM
