2002 Hyundai Accent brake cylinder
2002 HYUNDAI ACCENT
ROBERT UCCELLO
Brakes problem
2002 Hyundai Accent 4 cyl Two Wheel Drive Manual
any suggestions how to remove the left hand side bolt to replace the cylinder. Unable to do so with metric socket with ratchet. A wrench will not fit in the space.
Sep 16, 2008 at 12:47 PM
  • 31,937 POSTS
Hi there,
if you remove the bleeder & undo and move the brake pipe you should be able to get to the bolt with a 1/4"drive socket set.
Mark (mhpautos)
Sep 16, 2008 at 1:05 PM
