2002 Hyundai Accent arcing from harmonic balancer
130,000 MILES • 4 CYL • FWD • MANUAL
JOSEPH1127
Problem started as a hesitation when going up hill or when putting stress on the engine. I ran a code scan and got # 4 missfire. I changed the plugs,wires and coils then I cleared all codes. After all of that i noticed a bright blue spark and popping noise coming from the harmonic balancer. Its been about a month since i replaced the ignition parts and cleared the codes. It seems to run ok and there are no codes. But the spark is still there.
Apr 11, 2010 at 3:18 AM
  • 110,248 POSTS
Have you checked the condition of the crank sensor?
May 20, 2010 at 4:16 PM
JOSEPH1127
yes. I ruled that out since it is located neer the fly wheel and not the balancer.
May 20, 2010 at 11:13 PM
  • 110,248 POSTS
Just for the heck of it, check the ground on the engine block. Make sure it is tight, clean, and not damaged.
May 21, 2010 at 3:24 PM
JOSEPH1127
I will double check the ground. I did take some jumper cables and connected the engine block to the body and I still got the same result. Would jumper cables make a good enough ground to rule that out too?
May 21, 2010 at 3:41 PM
  • 110,248 POSTS
I would have gone straight to the battery. This one has me confused. After your last post, I thought about it and the only thing that came to mind was a weak ground and the power trying to find a good one. That is why I suggested the ground issue. Try it again, but go straight to the battery. Make sure the jumper is on a clean spot of the engine so it grounds properly.
Let me know what you find.
May 21, 2010 at 4:12 PM
JOSEPH1127
I tred running a jumper cable from the negative post on the battery to a clean spot on the engine. It didn't change anything. I did put some belt dressing on the belt. That stoped the arcing at idle speed but once you give it gas it just starts all over again. I have conciderd static electricity coming from friction on the belt. But the arc that it is producing is very large and bright blue. It Almost looks like a spark from a plug. any more ideas would be apretiated. Thanks alot.
Jul 16, 2010 at 9:48 AM
  • 110,248 POSTS
Hi:
Good to hear from you, but sorry you're still dealing with the same problem. Without being there, the only thing I can think is the crank sensor. I know you said no to that, but there has to be a break down from that.
Jul 16, 2010 at 5:54 PM
