Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Accent
Body
Windshield
Washer
Not Working
2001 Hyundai Accent window washer for front does not work.
2001 HYUNDAI ACCENT
63,000 MILES • 4 CYL • FWD • AUTOMATIC
DOGEV
MEMBER
wipers work, rear wiper and washer works, but the front washer does not work. Is this a blockage or a pump problem?
Apr 18, 2009 at 1:22 AM
MERLIN2021
Experienced Mechanic
Use a voltmeter and have a helper active the pump while you check for voltage at the connector. If there is volts there, replace the washer pump.
Apr 18, 2009 at 1:25 AM
DOGEV
MEMBER
where would the connection be located?, to check for the voltage?
Apr 18, 2009 at 1:30 AM
MERLIN2021
The pump is at the bottom of the washer fluid tank. Remove the connector and test across the two terminals.
Apr 18, 2009 at 1:50 AM
DOGEV
MEMBER
thank you. I will try that and get back to you with a donation.
Apr 18, 2009 at 1:59 AM
MERLIN2021
Your welcome!
Apr 18, 2009 at 2:08 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
