2001 Hyundai Accent window washer for front does not work.
2001 HYUNDAI ACCENT
63,000 MILES • 4 CYL • FWD • AUTOMATIC
DOGEV
wipers work, rear wiper and washer works, but the front washer does not work. Is this a blockage or a pump problem?
Apr 18, 2009 at 8:22 AM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
Use a voltmeter and have a helper active the pump while you check for voltage at the connector. If there is volts there, replace the washer pump.
Apr 18, 2009 at 8:25 AM
DOGEV
where would the connection be located?, to check for the voltage?
Apr 18, 2009 at 8:30 AM
MERLIN2021
  • 17,250 POSTS
The pump is at the bottom of the washer fluid tank. Remove the connector and test across the two terminals.
Apr 18, 2009 at 8:50 AM
DOGEV
thank you. I will try that and get back to you with a donation.
Apr 18, 2009 at 8:59 AM
MERLIN2021
  • 17,250 POSTS
Your welcome!
Apr 18, 2009 at 9:08 AM
