2001 Hyundai Accent Taillights and third light
2001 HYUNDAI ACCENT
61,400 MILES • 4 CYL • FWD • AUTOMATIC
BOBS07
Rear lights will not go off, checked relay under hood ok, checked fuses under dash ok, I did look at the brake switch at the pedal, I pulled the white part off the actual switch and there is a pin sticking out of that and the realy part dosen't fit tight in the housing.Could that switch be bad? And if so is there anyway to check it before I buy a new one??
May 28, 2008 at 4:26 PM
there is a pin sticking out of that and the realy part dosen't fit tight in the housing. Try tightening it up and adjsust the plunger and see what happnes.
May 28, 2008 at 7:34 PM
